Mowing BX mmm removal goof
   / BX mmm removal goof #1
rbarker
Platinum Member
Massachusetts
BX 25
I needed to remove my mmm today and I decided to turn the wheels sideways this year because I just don't have the strength or energy to wrestle the deck out from underneath the tractor with brute force anymore. I moved the tractor onto the paved driveway, raised the deck all the way up and then set the wheels on the lowest sideways hole to give maximum clearance, never checking to see if the wheels actually touched the ground when lowered. It dropped with a clunk when I disconnected it and the metal deck was sitting on the pavement under the tractor. I wound up dragging my rolling floor jack from the shed across the lawn to get the deck up off the ground and set the wheels at the highest sideways hole where they now suspended the deck and allowed me to roll it out with no trouble.
Needless to say this is not a mistake I am anxious to repeat which is why I share it with my fellow TBN folks.
Sent from my iPad using TractorByNet
   / BX mmm removal goof #2
I never even noticed that hole on my wheels until yesterday. Glad I didn't try to use them. And now I won't. Thanks.
   / BX mmm removal goof #3
When I rotate my mmm wheels, I put one side high and one side set low. It clears the lift arms a little better and is still easy to rolls out. The older I get, the heavier some things seem to get.
   / BX mmm removal goof #4
:eek:It seems to me that we should have a special forum for "Old Geezers" tips and tricks.
   / BX mmm removal goof #5
I'll second that! There are so many "little" processes that can make a difficult job so much easier and us "Old Geezers" can't use brute strength as efficiently as we once could. Like someone once said "work smart, not hard." Younger folks on this forum like to work smart too, so everyone wins!
   / BX mmm removal goof #6
I got a set of these from a dollar store for about $4 each. They fit perfect under each anti-scalp wheel. I drive my BX up on 2x6's first to get a bit more clearance. No need to rotate the mower wheels and it slides right out on my garage floor. Not sure but Harbor Freight might carry them also.
Shop Waxman 6-in Plastic Swivel Caster at Lowes.com
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
telescope boom (A56857)
telescope boom...
