Loader BX loader linkage problem
   / BX loader linkage problem #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
I was cutting grass and needed to raise the front bucket to clear a fence and it would not go up. All other functions of the loaded worked but up.
I pulled off the screen panel so I could see the linkage and when I did a nut fell out. I saw one of the threaded shafts at the linkage rods was missing any kind of nut so I put it on and started tightening down. It seemed to keep turning and turning so I stopped turning and gave it a try. It worked again.
My question is: there are double nuts on the other shafts and the outer nut looks different than the one I put back on. Should there be a second nut on this one as well so it will lock the nut in place? Should the first nut be tight as not to turn any more? I don't want to damage it. Is there a parts diagram that shows the linkage and parts?
Thanks in advance...
Never mind...I found the exploded view of the linkage on MESSICK'S site. I would recommend getting the parts diagram and list for your tractor there as well. Thanks Messick's.
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
Corn Reel (A50514)
Corn Reel (A50514)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2022 BRONCO GRILL, F-150 DECALS, ETC (A51244)
2022 BRONCO GRILL...
