BX length with FEL?
   / BX length with FEL? #1
r0GuE
West PA
ex-Bota Owner
My BX comes tommarrow with the FEL on. The problem is, everything I own is in my garage. (still remodeling my new old house)
Soo how long will the thing be, from the very back of the 3ph or ROPS (or whatever the furthest part of the back is) to the front of the FEL? I have to make some room. I think I can get 10' freed up. Is that enough?
Rogue
   / BX length with FEL? #2
Rogue,
I'm not at my house right now so I can't go out and do a measurement, but 10 feet might work. Keep in mind, however, that you will be using a counterweight most of the time while you have the FEL on. That's going to add significant additional length. I've noticed you've posted an inquiry a few days ago regarding counterweights. Sorry I didn't respond then. The general sentiment seemed to be that using an implement for a counterweight was more cost effective than buying a counterweight device.
That is true, however, a tiller or box blade will stick out pretty far - certainly adding more than 10 feet total.
I bought a New Holland weight bracket that is mounted on the 3PT hitch arms. Holds up to 7 - 50 LB weights and adds only a few inches to the total length of the tractor. I started with 200 LBS and found that was too light for some jobs. I use 300 LBS now and I keep that mounted all the time instead of my tiller.
On 5/19 I posted the info on where I purchased this, part numbers, prices, etc. Here's a repeat:
My dealer purchased the bracket from North State Sales. I don't know if this part number is NH or North State, but here it is.
The bracket is part number 7001 - I paid $94. The part number for the weights is 3113 - I paid $39 each for those. The bracket has this information on a label glued on: North State Sales, 2204 N. Church Street, Greensboro, NC, (336) 275-9578.
Hope this is helpful.
Frank
   / BX length with FEL? #3
Rogue, My BX with the FEL attached is just less than the 12' depth of my shed, giving me approx 1' of clearance with the 3pt raised. Needless to say, any 3pt attachments have to come off before I park her.
   / BX length with FEL? #4
Rogue,
Update: BX with FEL is almost exactly 11 feet. The New Holland 3pt weight bracket (described in my earlier post) with weights attached adds only another 8 inches. A very compact counterweight if you have a small storage space or just want to have a shorter overall profile for easier maneuvering.
Frank
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A48836)
2007 Hino 268...
78in Buckets (A49251)
Field Cultivator (A49251)
Field Cultivator...
300 Gallon Tote (A49251)
300 Gallon Tote...
Massey Ferguson 124 Hay Baler (A49251)
Massey Ferguson...
John Deere 5410 Tractor (A48837)
John Deere 5410...
