Mowing BX front mount mower
/ BX front mount mower #1
eno
PBG, FL
BX2200
Is it posible to mount a mower on the front on the BX, like the Ventrac tractor.
/ BX front mount mower #2
I would say yes it is possiable useing the quick hitch that mounts the snow blower. as to how handy it would cut I don't know. /forums/images/graemlins/smile.gif
I'm going to build a soccer field, and I think I will get a better cut if I use a front mount mower, the weight of the tractor compact the grass, so i won't have a golf like cut on the field, the ventrac has a front mount mower and all the tools the, problem is $$$.
/ BX front mount mower #4
I don't think that the weight of the BX and mower is that significant, but if you are really concerned about the weight of the BX's front wheels running over the grass before the mower, you may consider one of the 44" or 60" tow-behind mowers such as the Swisher brand that Tractor Supply and Northern Equipment sells. These mowers can be offset so that you can simultaneously mow with your BX's mid-mower and the tow-behind (cutting up to 10' on each pass). Or, using the same offset mode you can mow grass that the tow vehicle (BX, ATV, air-conditioned truck, etc) hasn't driven over yet.
The prices run from $899 (if I remember correctly) for the 44' mower to $1699 for the top-of-the-line Honda powered 13 hp 60' mowing deck. I think that this would be significantly cheaper than a custom built configuration, and would probably have a much larger resale market (compared to the custom built front mower) if you decided you didn't like the results.
Kelvin
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
(3) 6"X34'-1/4" THICK STEEL TUBING (A64280)
(3) 6"X34'-1/4"...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
AGROTEC ASE1054 TOWABLE SPRAYER (A64280)
AGROTEC ASE1054...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
