Oil & Fuel BX front axle oil?
   / BX front axle oil? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
What type of oil is supposed to be used in the front axle of a BX? I have not been able to find a specific designation in my owner's manual? I imagine that I can use motor oil if I like, but I'm wondering if Kubota has a specific recommendation somewhere that I just haven't been able to find?
Thanks
   / BX front axle oil? #2
From page 64 in the manual under Lubricants:
Capacity: 4.7L (5.0 U.S. qts)
Lubricants: Kubota Super UDT fluid or SAE 80-SAE 90 gear oil.
Hope this helps,
Jim
"See LUBRICANTS in MAINTENANCE OF TRACTOR section." I saw that all over the manual, found that in the table of contents, turned to page 64 about five times, yet somehow missed that all five times. :confused:
Thanks a lot Jim. That certainly helps!
   / BX front axle oil? #4
LOL:D we have all done this!!
   / BX front axle oil? #5
I have always just used gear oil just whatever i had laying around last time i used the same thing i used in the gearbox of my mmm
   / BX front axle oil? #6
I suggest you use a gear oil with an EP (extreme pressure), designation.
2019 Ford F-550 (A55973)
2019 Ford F-550...
2005 Caterpillar 928G Articulated Wheel Loader (A55973)
2005 Caterpillar...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
1994 International 3800 Bus (A54814)
1994 International...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
