Oil & Fuel BX front axle oil?
   / BX front axle oil? #1
RayCo
Veteran Member
Chester County, PA
Kubota BX24, Case 580 Super L
What type of oil is supposed to be used in the front axle of a BX? I have not been able to find a specific designation in my owner's manual? I imagine that I can use motor oil if I like, but I'm wondering if Kubota has a specific recommendation somewhere that I just haven't been able to find?
   / BX front axle oil? #2
From page 64 in the manual under Lubricants:
Capacity: 4.7L (5.0 U.S. qts)
Lubricants: Kubota Super UDT fluid or SAE 80-SAE 90 gear oil.
Hope this helps,
Jim
"See LUBRICANTS in MAINTENANCE OF TRACTOR section." I saw that all over the manual, found that in the table of contents, turned to page 64 about five times, yet somehow missed that all five times. :confused:
Thanks a lot Jim. That certainly helps!
   / BX front axle oil? #4
LOL:D we have all done this!!
   / BX front axle oil? #5
I have always just used gear oil just whatever i had laying around last time i used the same thing i used in the gearbox of my mmm
   / BX front axle oil? #6
I suggest you use a gear oil with an EP (extreme pressure), designation.
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51242)
HYSTER S50FT...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
2012 RAM 5500 (A52472)
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
