BX Flasher Guards
/ BX Flasher Guards #1
Yooperman
Kubota BX25
After "rearranging" the flashers on my BX for the last time, I decided to invest the time and make a pair of flasher guards. Hopefully the guards will keep me form damaging the flashers with my own body while trying to squeeze past my BX and at the same time keep stray branches, etc from damaging them when I am playing...errrr, working in the woods.
I know others on here have had the same issues with the flashers as I, so hopefully this will give others some ideas.
The one thing I may still do is put a wire mesh over the guards facing front to keep branches from entering straight on. Oh... a piece of plastic would be perfect. It would not cut down on the visibility.
/ BX Flasher Guards #3
Yooperman, great job on the flasher guards. Can you tell us more how you made them? What did you use to bend them, are they welded or brazed? Any info would be appreciated. Again great job!!!!
/ BX Flasher Guards #4
Really nice. I wish I had something like that. I've broken mine twice since I've owned my BX.
/ BX Flasher Guards #5
Wish someone like BroTek or BxPanded offered something like that, I would sure buy them.
/ BX Flasher Guards #6
To prevent the lenses from getting knocked apart, I put a single tie wrap around the waist (between the two lights.) Haven't had one get knocked loose yet.
/ BX Flasher Guards #7
Beautiful job! they look like they came from the factory. would love to have a set for my tractor.
/ BX Flasher Guards #8
Great job on those flasher guards.
/ BX Flasher Guards
I used 5/16 sq rod because that was what the salvage yard had. The guards are welded. To do the bending, I purchased a Harbor Freight Bench Top Bar and Rod Bender item number #38471. I used the 3" die that comes with the bender for the smaller semicircle bend. But, I had to make a 4" diameter die for the larger semicircle bend. (Just a 2" thick piece of 4" diameter round steel with a hole drilled in the center to fit the bender.) It takes a lot of trial and error and luck to get everything just right.
On my next trip to Harbor Freight I am going to pick up a die grinder to help to grind down the welds a litter better next time.
If I missed any info you are looking for, let me know.
Thanks for the kind words.
/ BX Flasher Guards #11
Those look great!
/ BX Flasher Guards #14
Nice job! Working with steel isn't easy. It appears that you have the gift. Thanks for sharing.
/ BX Flasher Guards #15
I will "take one for the team". You can send me those ugly prototypes and I won't tell anyone where I got them. Then you can make yourself pretty ones using your newly purchased die grinder. Those are nice substantial looking guards.
Take Care,
Doug in SW IA
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
