bx fel valve p/n's
   / bx fel valve p/n's #1
Anonymous Poster
Epic Contributor
bx fel valve p/n\'s
I'm wondering which valve was installed on my bx2200. I remember reading that the bucket dump was faster with the 4 way valve. My bucket will dump so fast that it slams the stops HARD when I throw the valve all the way over, to the point that I have to feather the valve if I don't want my ears to ring. Still getting used to it as the old loader was real leisurely about dumping the bucket.
I saw a mention of the part #'s before but can't seem to find it now. Anybody have the #'s handy?
Thanks,
DaveL
Re: bx fel valve p/n\'s
DaveL,
The manual that came with my loader valve kit says it is # BX2014 it is for a LA211 loader. I believe the loader for the BX2200 is a LA210 but I believe the 4 position kits are the same. It has a dump position(slightly right) and a fast dump position (far right). It also has a float position (far up) for keeping grade level or plowing snow. Hope I've helped!
Brian
Brian,
Thanks for the response. The valve on my bx is a Husco. It has the four ports for the two operations for the fel (boom and bucket), feed and return, and power beyond. It also has two plugs in the middle between the fel ports.
The part # on the nameplate is:
Husco
J02A3661 05
7J240-61011
9210-83F
I did a search on Husco and was not able to find a product listing, just advertising.
Would you or anyone out there know if this is a 4 way valve?? Is there any other way of identifying it??
Thanks in advance for your help.
DaveL
   / bx fel valve p/n's #4
DaveL,
I have the same valve on my BX220 FEL also. I was also trying to figure out if it was a four-way or what. Maybe there is somebody out there that knows. I asked my dealer about it and all the service guy said was that this was the one that comes with FEL and that is what they put on it. My dealer does not sale alot of the BX2200, but they are great with service. Hopefully somebody will come forward that knows about this valve.
Don W
Dave,
I just looked at my valve. The following #'s are on it.
H0282202 05
75532-62011
9210-84F
It also is a husco valve. Under the lever there is a Kubota sticker with the model, and serial #'s on it. Check and see which model # is on it. It should be BX2014 for the 4-way valve. Oh, and by the way I screwed up on the loader models (**** rookies). The BX22 comes with the LA210 and the BX2200 comes with the LA211. Also reading my manual for the loader the only difference is the 3-way has only single stage bucket dump as the 4-way has the two stage bucket dump ( or fast dump). If you take the lever and push it all the way to dump it will have a click like feel into the fast dump position. It dumps very fast and does bang off the bucket stops. Hope I kinda helped out here!
Brian
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53473)
NEW 2025 Load...
1990 PETERBILT 320 HYDROVAC (A53843)
1990 PETERBILT 320...
1996 JCB 506B Telehandler (A53473)
1996 JCB 506B...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
backhoe attachment for full size skid steer (A53421)
backhoe attachment...
