BX FEL Dolly Help!
   / BX FEL Dolly Help! #1
woodstock
Winnipeg, Canada
BX2200
Well I've made dollys for all my implements, now I want to make one for the FEL, but I haven't a clue what it should look like.
HELP Please!
Winnipeg, Manitoba
2001 BX2200 (30 hrs)
   / BX FEL Dolly Help! #2
Woodstock, I can't help you there. But since you have made them for other implements, could you share your design with me for a rototiller dolly? I'm getting ready to build one of these and right now I have a bad case of inventor's block.
   / BX FEL Dolly Help! #3
Woodstock, someone in the last few months posted pictures of the one he made, but I don't remember who or where./w3tcompact/icons/frown.gif It looked real good, though.
Bird
   / BX FEL Dolly Help! #4
Woodstock,
This is an interesting challenge. I haven't built one - but I have thought about it (daydreaming about getting a FEL for my BX). Unless you want lots of fussing around each time you take the FEL off, I would say that there are only a couple of ways to do this. First question is - what would you be making the dolly out of - lumber or steel?
Patrick
   / BX FEL Dolly Help! #6
Bird,
Your memory is better than mine - or Woodstock's ... check out who posted in the thread below /w3tcompact/icons/wink.gif
Loader Dolly
Patrick
   / BX FEL Dolly Help! #7
Harv - you beat me to it by seconds!!
   / BX FEL Dolly Help! #8
I'm getting ready to make a dolly for my FEL too. I have found the dolly for my tiller is invaluable. I can hook up my tiller in seconds because I can micro adjust the position which I couldn't do if it was sitting on the floor.
I'm going to make the loader dolly the same way-- 2X6 on the flat glued and screwed together, 3/4 plywood also glued and screwed, and real heavy duty castors. The glue I have found from wood working greatly increases strength.
   / BX FEL Dolly Help! #9
Woodstock, I was bettin' one of these sharper fellows, like Harv & RPM, would find it for us./w3tcompact/icons/laugh.gif
Bird
   / BX FEL Dolly Help! #10
I LMAO on this thread thinking of a FRONT END LOADER and DOLLY. Think about it.
Bluegrass, Pick It Up!
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2006 International 9400i (A52748)
2006 International...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
Genie GTH-644 (A50490)
