BX driveshaft to front axle universals...
   / BX driveshaft to front axle universals... #1
dieselbob69
WNY
'21 Kubota BX2380
Hi folks! I was wondering if anyone knows if any universals can be had that are greasable? I dislike sealed universals. I am also not too fond of the amount of slop the yokes have on each end of spline,or were they designed that way?These are on a BX1870. I did look up price of new yokes, K2561-16810 is front one and lists $55.73, K2561-16820 is rear one and lists for $88.78, not sure if new ones would be greasable or not....
   / BX driveshaft to front axle universals... #2
I bought new joints for the front shaft on my BX2230 last summer, and they were not greasable either. But then they have lasted 16 years and 1400 hours. I don't know if joints the same size with zerks are available or not.
   / BX driveshaft to front axle universals... #3
Greasable universals are actually weaker due to the passages drilled into them. A good quality sealed joint will last just as long provided you don't damage the seal on assembly.
   / BX driveshaft to front axle universals... #4
After 18 years and about 1300 hours on my BX2200, I lost the rear U-joint on my front driveshaft. The roll pin that holds the u-joint in place broke, and it fell off...I could not find it, so I ordered a replacement.
After I installed the replacement, having taken the MMM off to make the job easy, I decided to clean off the top of the MMM and found the original U-joint laying there. Still seems as good as new, so I have spare I will likely never need...Or would not have until I said that...LOL
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
Cushman Electric Cart (A55851)
Cushman Electric...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2012 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2012 FREIGHTLINER...
