Rear Blade BX combo rear blade and rake?
   / BX combo rear blade and rake? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
Anyone make or have one? I would like to buy both and they seem like the same thing. I would think the same attachment would hold both. Or am I just cheap?
   / BX combo rear blade and rake? #2
donn12:
Woods and LandPride both make grader blade rake combo's. I do not know if they make one in the BX size. Jay
   / BX combo rear blade and rake? #4
I've been thinking about making one that can be used for multiple attachments.
Here is just a crude drawing I started that's not finished, but basically allows you to make different attachments that slide into one 3pt receiver hitch.
I am thinking about something like a $500 landscape rake only you could remove the rake portion and use a straight blade when you needed it. Maybe an additional $150 for the straight blade? I don't know I have never seen anything like this.
   / BX combo rear blade and rake? #6
I recently picked up a used York RS series, 60" with the drop down scarifier, drop down blade, and wheels. I have not used it yet but it looks well built and versatile.
Anyone out there have experience with an RS York rake?
   / BX combo rear blade and rake? #9
I had the same idea after I broke a weld on my rake. I was experimenting with gauge wheels and put a bit too much leverage on the joint that held the rake to the 3pt arm. I drilled out the weld & put a big bolt through the arm and rake. now, if I had a blade, I could unbolt the rake and bolt the blade on. I'm still without gauge wheels but I've got another idea brewing for that...
   / BX combo rear blade and rake? #10
I bought my rear blade from eBay Store - Betst Companies: Flail Mower, Backhoe, Wood Chipper
He said the plans were to make a box blade and a landscape rake that replaces the blade- just unscrew the big wingnut and change. He doesn't have them yet, but I love the blade.. it offsets and has lightduty rippers on it too
Super Rhino 8 Foot Angle Scraper 3 Point Hitch (A59225)
Super Rhino 8 Foot...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
We do NOT accept credit cards as payment. (A57149)
We do NOT accept...
case 370 glass door never installed (A56436)
case 370 glass...
2019 WANCO  LIGHT PLANT (A58216)
2019 WANCO LIGHT...
