Backhoe BX Backhoe Availability
/ BX Backhoe Availability #1
Anonymous Poster
Epic Contributor
The 225 CJM Hydra Link Backhoe can be attached to any tractor 16HP and upwards.
FEATURES:
*Padded Bostrom seat
*180o slew system,trunion mount rams
*Twin joystick control valve
*replaceable bushes
*optional machine mount systems
*20 greasable points
*Individually activated hydraulic legs
*10" travel on hydraulic legs
*Hoses double braided 1/4"
*Replaceable bucket teeth
*Tear drop retainer on pins
*A-frame linkage support
*Maximum depth 5'6"(1675mm)
*Maximum reach 7'1"(2160mm)
*Weight 260kg
*operatable from PTO or hydraulics
Excellent for small tractor application - lightweight but strong.Used by plumbers, landscape gardeners and local government.
Backhoes for small tractors ~ 16 PTO HP
/ BX Backhoe Availability #2
John
Nice, but I think this one is a sliker setup.The stablizing outriggers look more substantial.
Recommended tractor size from 12 to 35 HP.
6’6” Maximum Digging Depth - 9’0” Reach.
Category I 3Pt. Rigid Hitch Mounting with Kelley Stabilizing Kit for maximum digging power.
Selected quick attachable semi-rigid frame kits for some small diesel tractors and some larger lawn and garden tractors also available.
Fold out Hydraulic Stabilizer legs with pivoting standard steel pads.
Adjustable folding cushioned seat.
Available bucket sizes 9”, 12”, and 15”.
All buckets are designed with hardened steel cutting edges and welded 1-1/2” wide hardened steel bucket teeth for digging in all types of soils.
Buckets with replaceable “2A” points optionally available.
PTO 540 RPM Independent Hydraulic Pump System is available complete with reservoir, 4.2 GPM pump, filter, hoses, and mounting parts.
Easy to mount and detach, Affordable and Economical to own and operate.
http://store.edneyco.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=15&p_catid=2&sid=3fK2rT0GSAAGCC5-44101497852.d6
Winnipeg, Manitoba
2001 BX2200 All Kubota FEL, Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
/ BX Backhoe Availability #3
How much though???
Specifications
(Specifications may vary depending on tractor model and are based on boom pivot 11" above ground level. Tractor front counter weights may be needed for stability and safe tractor operation. Specifications are subject to change without notification.)
A Maximum digging depth 6'6"
Digging depth (two foot flat bottom) 6'0"
B Reach from swing pivot 9'0"
C Transport Height 5'3"
D Bucket Clearance 5'0"
E Bucket Rotation 165°
F Swing Arc 140°
G Stabilizer Spread Down (Operating) 7'0"
H Stabilizer Spread Up (Transporting) 5'8"
Bucket Pry-out power - in excess of 4076 lbs.
Bucket curl power at cutting lip 1870 lbs.
Crowd power at end of dipper stick 1728 lbs.
Lift at end of boom 640 lbs.
Lift at end of stick with boom and dipper stick extended 375 lbs.
Hydraulic system relief valve setting 2000 psi
Hydraulic flow requirements 3.5 to 4.0 GPM
Shipping weight (less bucket) 565 lbs.
Recommended tractor size 12 to 35 HP
Boom cylinder Bore 2.5"/Stroke 14"
Dipper stick cylinder Bore 2.5"/Stroke 10"
Bucket cylinder Bore 2.0"/Stroke 14"
Swing cylinder Bore 2.5"/Stroke 7"
Stabilizer cylinders (two) Bore 2.0"/Stroke 8"
Bucket Width Cutting Width Number of Teeth Weight Heaped Capacity Struck Capacity
9" 9-1/2" 3 34 lbs. 0.64 cu. ft. 0.47 cu. ft.
12" 12-1/2" 3 40 lbs. 0.85 cu. ft. 0.63 cu. ft.
15" 15-1/2" 4 45 lbs. 1.06 cu. ft. 0.79 cu. ft.
Stephen... what kind of price is on the Kelley?
/ BX Backhoe Availability #5
If I had the kopecs I'd go for the kelly. I would like to paint it Kobota Orange though.
<font color=orange>George</font color=orange> /w3tcompact/icons/smile.gif
/ BX Backhoe Availability #6
John,
I am not sure and I'm almost afraid to ask. Only because it might not be too expensive if you know what I mean.
See my hobbies if you don't understand.
Winnipeg, Manitoba
Many years ago, an ol' timer said to me...
Johnny to make money, you find something you can make for a penny... sell for a dollar... and make sure it's habit forming...
I'm still trying to find that something... /w3tcompact/icons/wink.gif
I had a bigger version of that type of outrigger 3pt backhoe once, unless ground is HARD and FLAT weight cannot be removed from tractor and your tractor will be under much more stress then it is designed for. 3 pts in general are a disaster UNLESS and this is a big UNLESS you use it very lightly, no stumping no anything but digging in the sand. Go with a frame mount or rent something. I'm not trying to be negative, I know there are folks with 3pts that are happy with them. Even most of the frame mounts I have seen have to be seriously reinforced to even think of using the backhoe as if it was an integral part of the tractor. Look at a B21, or an L35 to see how a small compact tractor removable backhoe should REALLY be designed. Those are super durable.
del
del...
I only posted the "backhoe" option because of BX owner's interest...
While I may not agree using a BX, myself I would certainly go to a heftier tractor frame, axles etc. if I was going to use a backhoe...
The forces and stresses of a backhoe arrangement would definitely tax the "can do" BX to a point of abuse... in my opinion. /w3tcompact/icons/frown.gif
/ BX Backhoe Availability #11
twg67
We all kinda lazy around here if you put {url} infront and {/url} behind the link your posting, lazy people like me can just click on it and automatically go there. you have to use [ ] the square brackets.
Thanks for the link.
http://www.northerntool.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=352684&prmenbr=6970
Winnipeg, Manitoba
2001 BX2200 (15 hrs) All Kubota FEL,Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
/ BX Backhoe Availability #12
Not entering the backhoe "can do" or cannot do argument since I am pretty sure there will be a Kubota unit for the BX but I am interested for curiosity sake---what is that little blue tractor in your picture there John Miller III if I might ask /w3tcompact/icons/smile.gif ? JRW IV
Well...well...well.. {3 deep subjects...}
Mr. JRW IV... Hi!
I knew it would only be a matter of time before you jumped in here.../w3tcompact/icons/wink.gif
JR, I really don't know what that <font color=blue>blue</font color=blue> tractor is... I'm assuming it may be a Ford? {I got the picture from the backhoe mfr. website... not my tractor}
Let me give my definition of "backhoeing"... I'm from the old school... being able to rip those stumps out of the ground, digging a house basement, making a man-made pond to swim in, heavy duty construction digging, etc....
Using a BX for those things would be abuse on the tractor and nuts on the operators part...
Now using a backhoe on a BX for trenching purposes, small teeny weeny stumps {busting your chops} in hard to get to places... why yes!
JR, I've been meaning to ask you, do you work for a major airline as an A&P mechanic... and did you go to school in the midwest for A&P, cause it seems like the major A&P is mid USA?
By the way, I don't currently have a backhoe... though it's on my long wish list... but we'll get there eventually... /w3tcompact/icons/smile.gif
/ BX Backhoe Availability #14
Good advice del./w3tcompact/icons/smile.gif Well worth listening too.
Al
/ BX Backhoe Availability #15
Jeez, John, I only wanted to know if you were familiar with that blue tractor and I said I was not going to enter the back hoe argument and so I am not!
John, your other question, no--I work for a major manufactuer as an Experimental Mechanic. Also--no--I got my A&P while living in Arizona (Phoenix area). Actualy, right now there is a tremendous demand for A&P's in all areas of expertise from the airlines to FBO's and refitting centers and slowly the pay scale is beginning to reflect that. Bizjet aviation is the wave off the future with the fractional/co-op ownership programs that let small companies buy a piece of a jet--very popular. By the way, I am more than "just a mechanic", I have 4 college degrees, give or take, of various sorts including advanced studies. Right now I am a mechanic because I thought the best way to learn something well enough to teach it is to do it first. Only after I have busted my head and hands with tools in a dark interior of an aircraft could I stand before young people and tell them how to do it with any credibility. J
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
2004 KENWORTH 10 WHEELER GRAIN TRUCK (A64278)
2004 KENWORTH 10...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
