Tires BX AG tires
/ BX AG tires #1
blackmajicwoman
Westport, MA
Kubota BX1500, ZD331
It all started when I wanted to put a set of loaded AG's on my BX1500 to get better traction while snow plowing. As I found out the hard way, you can't put 18x8.5-8 AG tires on a BX1500...the inner rim does not fit over the front axle hub!
I had purchased a set of barely used (99%) AG's off a BX1830 from a dealer in AZ, who assured me they would fit my BX1500. I was a little disappointed to find the rear rims faded when they were delivered to my house, but the dealer had them store unprotected outdoors for the summer. I brought the tires to my dealer in Westport, MA who not only confirmed this, but loaded them with CC for me. In addition to that, the AZ dealer shipped me (2) left rear tires! So the dealer had to reverse one for me. In addition to that, he had to reseat the other "correct" rear tire. By doing this, the mechanic beat up the rims really bad, as the tire was seated really tight to the rim. The good thing was that the dealer filled the tires for free. When I got home to swap out my turfs for the AG's, I found the rear AG's had very little clearance of the rear fenders. When I went to put the fronts on...well, they didn't fit. Really disappointed, I left the rears on to plowed through 8" of thick, heavy, wet, white stuff the following day. I will say I found an extreme difference in performance. The rears did not slipped once!
Figuring I can get away with ordering a pair of 16x7.5-8, I didn't realize I was setting myself up for a serious problem. When I called Ronnie at Tractorsmart.com, he said I would have a tire mismatch and do damage to the FWD. Not wanted to risk that, I bit the bullet and purchased a full set of AG's for the BX1500. For $360, they were shipped right to my door.
With that out of the way, I now have a set of barely used AG's (with rear rims beat up) for any other BX except the BX1500. I would like to offer them to one of you. I am willing to drive 50 miles from 02726. The rear's are heavy (about 160lbs), so I can't/won't ship them. If interested, let me know and make me an offer, as they are doing no good stacked in the corner of my garage. I am willing to let them go cheap. I will post some pics either tonight or tomorrow morning. Hopefully, I can make some BX non-1500 owner happy.
/ BX AG tires
And now for the pics. Here's pic #1:
/ BX AG tires
Pic #2:
/ BX AG tires
Pic #3:
/ BX AG tires
Pic #4:
/ BX AG tires
Pic #5:
/ BX AG tires
Pic #6
/ BX AG tires
Pic #7:
/ BX AG tires
Pic #8:
/ BX AG tires
Pic #9:
Feel free to ask or request any info on this set of AG's. Thanks.
/ BX AG tires #11
will they fit a BX22 and how much is cheap (send me a pm)? also how close are you to the Stockbridge area (Berkshires)?
thanks
/ BX AG tires
The rims cames faded, but my dealer's mechanic was the one the beat the heck out of them. It is as though he beat the tire off the rim with a hammer!
/ BX AG tires
...because I bought the rims from a dealer online in AK, of which I received (2) left rears. My dealer said he doesn't feel responsible for a mistake another dealer made. In my opinion, I think he was a tad bit upset I went to another dealer in the first place.
I did contact the dealer in AK and he said he would make good on the rims, but I would have to ship him the old set, which would require me to unload the CC and pay the shipping cost. It wasn't worth the hassle and aggrevation. With that, he gave me a credit to purchase anything else I wanted up to the value of the rims.
/ BX AG tires #16
I know this is all water under the bridge at this point but the dealer that beat the &$^# out of the rims should have replaced them whether or not you bought them from another dealer. I used to know how to use a tire machine and there is no excuse for beating the **** out of the rim like that. If he charged you for it then abusing the customer's property is not something you can usually come up with an excuse for.
As far as the fading that might be normal - when I got my BX23 from the dealer both of the back rims were faded the same way. The fronts looked fine. I was going to complain about it but I had seen other BX's with this same problem so I figured they were all like this. Kubota ought to complain to their rim manufacturer that their paint stinks but that was a battle I didn't have the time to start when I got the tractor.
/ BX AG tires #17
That's too bad it worked out the way it did, but at least you got what you wanted in the end.
I've had BX tires changed in the past with limited success. The steel is very weak. Ever wonder why the price of a tire alone is within a few dollars of a wheel/tire set from your dealer????
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A65563)
2016 Hino 195h...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
Parker 500 Auger Grain Cart (A66285)
Parker 500 Auger...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
