Mowing BX 60" Mower Deck Question....
   / BX 60" Mower Deck Question.... #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
BX 60\" Mower Deck Question....
What causes the MMM to go out of adjustment. I am careful with mine not to hit rocks and other obstructions. I noticed this last cut, that one side was lower than the other by a full inch when measured at the edge of the deck. I checked all mounting locations and it is properly installed. I removed the deck and found a lot of clippings underneath. I am in the process of cleaning these out, but I know that the deck is definitely off balance. Any thoughts as to what might cause this sudden loss of alignment??????? I checked the blades and they are all in alignment. Also checked the spindles for lateral runout and there is none..... /forums/images/graemlins/frown.gif
   / BX 60" Mower Deck Question.... #2
Re: BX 60\" Mower Deck Question....
Are there adjustable arms from the three point hitch to the mower lift assembly?
Egon
   / BX 60" Mower Deck Question.... #3
Junkman,
This is just a guess...could it be the weight of all that grease you pumped into the spindle on the low side? /forums/images/graemlins/grin.gif
On a less serious note, could one of the nuts on the self-balancing assembly have come loose, causing spring pressure to be different and the deck to pivot, lowering one side and raising the other?
I remember the manual showing something about how they should be set. Maybe this would be a first point to check. Other than that...don't have a clue...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2006 John Deere 6320 (A50120)
2006 John Deere...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
