BX 2750
/ BX 2750 #1
whatever1
Earth
I have a BX2750 and have noticed a change over the years.
On the back side of the blower ( behind the auger) there seems to be an increasing build up of snow. When I first got it it stayed clean while blowing snow, but the last year or so the has been a substantial build up.
Question: Could the auger be worn down causing higher clearence in the back ? If so should the auger be replaced or is there a kit to attach to the auger to take up the space and keep the back clean ?
The edge of the auger has little raised sections that have a shiney edge to them.
Thanks
/ BX 2750 #3
The gloss finish to the original paint eventually wears down and allows the snow to stick.
Best solution- spray the whole blower with Fluid Film and nothing will stick for multiple storms. You could also choose to apply an automotive wax to that area.
/ BX 2750
SNOWBLOWER IMPELLER KITS
This web page sells rubber bolt-on pieces to close the gap created by wear.
I have thought about buying them for mine.
Thank You but it looks like it is for the impeler (fan) in the rear of the blower. I am looking for something for the auger ( the part that the snow sees first )
/ BX 2750 #6
My 2750D is about 3 years old with about 15 hours of actual use. I use it on a paved driveway so no gravel. I have always had some snow buildup between the auger and the housing, maybe 1/2 to 3/4" thick. It does not seem to be getting worse and I do not see signs of rubbing/ wear. May just be the way it is designed.
Update, I just went out to blow the driveway. Here is what mine looks like right after blowing
/ BX 2750 #7
I would do as mentioned above and spray the surfaces with Fluid Film, or Ariens Sno-Jet Spray, or Snow Jet, or wax it. I had trouble with my 2750D plugging up with real wet snow last year and hope to avoid that situation this year by using one of these products. I have 2 layers of Snow Jet on right now and will have a third by the end of the day.
/ BX 2750 #8
Has anyone removed the wire guard on the front of the chute? The two times mine clogged solid last year it looked like if that wasn't there it might have cleared itself so I was thinking of trying without it.
Sent from my iPad using TractorByNet
/ BX 2750 #9
Me.
Mine has been off for 3 years now & amazingly I still have all my digits.
/ BX 2750 #10
Me. Mine has been off for 3 years now & amazingly I still have all my digits.
LOL that's always handy! I won't go anywhere near the business end of the blower when it's on since 1) the tractor dies the second you get off the seat and 2) I don't fancy a face full of snow so the guard is of questionable value.
/ BX 2750 #11
I took the wire guard off because it was too hard to clean out if it did get plugged. I carry a crowbar with me to clear it, but i haven't had
to since I removed the guard. I even turn the engine off to clean my blower out. Better safe than sorry.
/ BX 2750 #12
Guard off, same here. One more step before cleaning, besides shutting off the engine, is to unload the PTO by switching the PTO to rear only. It unloads any force if bound up and also makes it much easier to clean.
Be safe, NO SCARFs around your neck please! Growing up, there was a kid that got pulled into the blower by a scarf. Not good. Same for any loose clothing around rotating devices.
/ BX 2750 #13
In a completely feels-good move, I reversed mine!
The lower part of the chute is still blocked to hand access and the top, bent out- does not interfere with snow & slush exiting.
KSI Conveyor (A63689)
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
