BX 2660 Front Axle Oil Capacity
   / BX 2660 Front Axle Oil Capacity #1
Usta
Central Vermont
2008 Kubota BX2660
Anyone Know For Sure how much oil the front axle actually takes? The manual says 5 quarts.
Reason No. 1 for asking is my manual says 3.7 quarts for the crankcase oil with filter when it actually takes 4.25 quarts to fill it. Had to go buy another quart to finish the oil change. So I now question the accuracy of the manual for the front axle also.
Reason No. 2 for asking is I want to be sure I have enough oil on hand before I change it. I plan to use SUDT hydro fluid and hopefully I have enough left over from the 5 gallons I had before I changed the tranny fluid.
   / BX 2660 Front Axle Oil Capacity #2
Just use 90W gear oil. Big jug is cheap and it tends to cause less leaks than SUDT. Better *and* cheaper.
Note after you fill the axle, the level WILL go down after a few hours as lube works its way throught the bevel pivots. Keep an eye on it and top off as needed.
   / BX 2660 Front Axle Oil Capacity #3
5 quarts should be correct. When changing the oil, be sure to remove the vent plugs at the top of the outer gear housings. Many folks seem to miss this step, and can't get all the oil in on the first try.
I would recommend using gear oil over SUDT... fewer leaks down the road.
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
STORAGE FEES (A53426)
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
