BX-25 Pics
/ BX-25 Pics #1
Proletarian
North of Atlanta
BX-25 / BX-1830
For your viewing pleasure.....:p
/ BX-25 Pics #2
Good luck with the new machine. I got a 2008. I see they upgraded the rear wheels and added to two studs to hold the wheel, while you sock it up. Wish I had that feature when I put the loaded rears on my BX25.
/ BX-25 Pics #3
...and she's dirty, too :thumbsup: Nice setup...
/ BX-25 Pics #4
Putting the loader down will make it much more stable. Take the weight off that front axle.
/ BX-25 Pics #5
Jealous! I've only got my BX 2230 to play in the woods. Unfortunately, I have a good sized tree leaned over on a 20 degree slope to work on with only my bucket, no backhoe. Looks really fun!
/ BX-25 Pics
@swick1: Thanks, I just didnt want to drop it on the concrete. I was looking for my water service line so I was digging easy, just peeling back the layers carefully. When I dig aggresssive I curl the bucket under and lock it in the dirt and go to town. I'm in the process of installing a PRV (U5B), double check backflow and a balll balve to add (extend) an irrigation system to my back yard. Having this hydraulic shovel sure makes the task fun. :D
/ BX-25 Pics
@TEG:
Quote: I fyou are thinking about buying a L3200 or L3800, try raising the 3 point hitch very slowly with a box blade on... see if you can live with the Jerky Hitch - First!)
_________________________________________________________________
I had an L2800 with the jerky feature you mention. I found sliding the lever quiclky and smartly to where you wanted it eliminated the jerk that was felt. doing it slowly however did cause the jerking.
/ BX-25 Pics #9
...I found sliding the lever quiclky and smartly to where you wanted it eliminated the jerk that was felt...
:D What worked best for me was to bug the dealer until he installed a Grand L valve... :p It works much much better...
I've had that quote on and off since I got to TBN... I've helped several people get their valves changed out... Now I keep it there to informed newbies to check out the machine *BEFORE* buying it and complaining afterwards. :2cents:
I should add that I was doing a few things that needed to raise the 3ph ever-so-slightly (600 lbs out on the end of a boom pole and fine grading), I can do that with the new valve.
/ BX-25 Pics #11
Be careful. This tractor will get you into more work than you can imagine :)
I'm building a grapple bucket now for my 1026r because I don't like what's on the market in this size range. I'm thinking about making it a kit to sell. We'll see.
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
