BX 25 HST Cooling Fan Replacement
   / BX 25 HST Cooling Fan Replacement #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Has any one figured a shortcut way to replace the HST fan other than the long drawn out process explained in the WSM? The dealer wants $500 to do it. Says it takes 4 hours of shop time. All to replace a $12 fan. Most of the time is removing stuff and putting it back to get the shaft out. It is obvious Kubota used this a a gimme for dealer shops as I see several ways to make it easier than moving the engine if it is a manufacturing detail change. Cannot tell from the WSM and Parts Manual how much end play the shaft has built-in but there is a spring on the end of the shaft.
There has to be a better way!
Ron
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
Fifth wheel multi use trailer. (A53472)
Fifth wheel multi...
