BX-24 Temp Sensor Broken
   / BX-24 Temp Sensor Broken #1
DickS
U.P. MI
JD 265, Kubota BX24
I just noticed my BX was running very cool. Popped the hood and noticed the spade connector on the temp sensor had separated from the sensor body. The spade was still in the receptacle on the end of the wire. It obviously vibrated loose from the post on the sensor. I was able to snap it back on but it vibrated loose again. I then tried to peen the post on the sensor and was able to get the spade to stay on but it is still loose. Any suggestions on how to re-attach or should I just bite the bullet for a new sensor?
   / BX-24 Temp Sensor Broken #2
Can you slightly crimp the connector?
Don
I tried to crimp the connector to the post but it doesn't stay tight. Perhaps some hardening epoxy will work. I'm reluctant to try silicone because it may insulate the connector from the sensor.
   / BX-24 Temp Sensor Broken #4
Not sure how much of a working surface there is, but can you get at it with solder?
Don
   / BX-24 Temp Sensor Broken #5
If you are still under warranty, get it replaced. If not you may have to bite the bullet and buy a new one. Soldering is the only fix that I think will last, but you may melt the adjacent plastic trying to do it.
Paul
   / BX-24 Temp Sensor Broken #6
I second the motion for soldering. very easy to do if you done it before
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2008 INTERNATIONAL DURASTAR 4300 SERVICE TRUCK (A50854)
2008 INTERNATIONAL...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
