BX-24 Sprinkler/yard/fence project.
   / BX-24 Sprinkler/yard/fence project. #1
Singlecoil
Eatonville, Washington
Kubota BX-24D Cub Cadet LT42e
I spent many an hour on this little project this spring. I ended up with about 45 hours on the tractor to bury 700 feet of sprinkler pipe, build 225 feet of fence, spread 40 yards of topsoil, and spread 20,000 pounds of drain rock.
This was a new house on 1/5 of an acre with an unfinished backyard. The ground here by Mt. Rainier is glacial silt and clay, so drainage is definitely an issue. We elected to go with the drain rock around the back of the house to have a somewhat stable platform for the barbeque and an eventual picnic table. We live near a quarry so 20,000 pounds was only about $300. The right side of the back yard I scraped down with the box blade and built a retaining wall. This was so the neighbors could backfill their side to make a flatter yard for them. We used a few 10 foot fence posts in that area by the retaining wall. The fence was designed to look the same on both sides so the neighbors would have a consistent look when they finished their other sides. The back side has 1x4 cedar trim pieces stained to match the 2x4 treated fence rails on the other side. The gates are 5 feet wide, wide enough for a BX though I hope I don't need it back there anymore :D I used a 9 inch auger on the post hole digger. We did hit a fair number of big rocks so my new favorite tool is not the BX, it's the cast iron digging bar.
There are six sprinkler zones: left strip front yard, back yard, front yard, and 3 garden zones along the fence perimeter in the back yard. I used black poly for all of it and learned a lot in the process. A propane torch is your friend. The backhoe worked great digging up the backyard, but largely made a mess of areas that already had sod. My sod was lousy and I had planned on top dressing it with soil and seed so I really didn't care a whole lot about messing it up.
We wanted to do everything organic so the lawn doesn't look all that spectacular. There are some days when I would love to accidentally drop some weed killer on the lawn, but then I would have to find a new place to live as the wife would take exception to such action :) The lawn was drop seeded and we used Ringer Lawn Restore for fertilizer from Home Depot. I bought a lousy drop spreader and over fertilized some areas but eventually they filled in.
Since the neighbors kicked in on the fence, the total cost was about $3500. When you consider the added value to the home is in the $10,000 to $15,000 range, the tractor looks even shinier in the garage :D
On to the pictures. The order got messed up when I uploaded them so you have to start at the back and work forward. Click on the link below then keep hitting previous image to see the rest.
Hopefully that will work.
http://www.tractorbynet.com/photos/showphoto.php/photo/3713/sort/1/cat/500/page/2
   / BX-24 Sprinkler/yard/fence project. #2
You've really been working that BX! How close are you to Mt. Ranier? I was just there about a month ago. I would have assumed a sprinkler system would not be necessary there, unless you live on the eastern side of the mountain. I wish I had your tenacity and planning. I have five acres that need everything you've done, and I've barely scratched the surface, so to speak. I have time though. We plan on being here for many years.
I know what you mean about the organic issues. Until I bought this property, I had never used either a pestacide or an herbicide. For a standard city lot (approx. 150 by 50 feet here in the Twin Cities), that was manageable. For 3 acres of lawn, 1/2 mile of gravel driveways and mulched paths, pulling out weeds by hand is just not possible. I do that where I can, but have broken down and bought weed killer. So, I've purchased two sprayers (backpack 3 gallon and hand held single gallon). Its not my wife that has the issue, its me.
We're about 15 miles as the crow flies due west of Mt. Rainier in Eatonville. It seemed like it was raining everyday in May and June when I was working on this. Our summer months are very dry, though. It has probably only rained a couple of days since the fourth of July. I dug an 80 foot trench around the back of the house to feed the front yard, then it rained for a week before I could get the pipe in and finish the job. I ended up having to buy a pump to get the water out before I could continue. At the time it didn't seem like a sprinkler system was worth all the hassle, but I'm sure glad I did it now.
I know the lawn would look better if I had used weed and feed, but when the 10 month old is crawling on it and putting grass in her mouth, it definitely makes one feel better knowing there aren't any chemicals on it.
   / BX-24 Sprinkler/yard/fence project. #5
Was the drain rock delivered at that price? I need a source in/near Olympia for road base and drain rock...
The supplier I used last year is too busy with his contractor customers this year.
proudestmonkey said:
Sounds nice. Do you have a clear view of my favorite mountain peak?
Actually we don't have any view at all right here. The next project is building a house on 20 acres near here with an unobstructed view of Rainier. One of these days...
Half was delivered as I split a dump truck load with one of the neighbors. The other half I picked up in pickup truck loads. It is far cheaper to get it yourself, about $15 a load for any kind of rock. Delivered here locally it was about $350 for ten yards. You might give them a call and get a quote for Olympia.
I just did a search on their name, Lynch Creek Quarry, and they have an outfit in Olympia.
http://www.superpages.com/yellowpages/C-Quarries/S-WA/T-Olympia/
The one I went to was in Eatonville.
http://www.amazon.com/gp/yp/B0003S91MC/103-1051206-5462228?ie=UTF8&n=10278291&v=glance
2022 MAXEY TRAILER MFG 18 TANDEM AXLE CAR HAULER TRAILER (A52472)
2022 MAXEY TRAILER...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
