HVACDIESEL
- Joined
- Sep 28, 2008
- Messages
- 17
What RPM'S DO you cruise around at? Use the FEL? Use the rear loader?When I bought my machine the salesman said 1/2 to 3/4.
I have a BX24. I just spoke with the Kubota regional service rep and he stated that Kubota prefers that while in use (esp. when using the loader or backhoe) that the engine is run at full throttle. He also added that although you may be able to operate the loader at lower rpm's, it's actually putting a drain on the engine to do so.
All machinery should be ran WFO wide *&c*ing Open, as thats where the machine is cools its self better and is made to run. This is the reason lots newer ag equipment (combines & spray coops) will only run wide open when being used.
The quickest way to burn up a air cooled motor is to run it @ 1/2 throttle.
