BX-24 Lug nut torque
   / BX-24 Lug nut torque #1
HVACDIESEL
What is the front and rear lug nut torque for a BX-24
THANKS
   / BX-24 Lug nut torque #2
THANKS
I do not have a bx 24; but is one to assume that you do not have a manual for the machine?
   / BX-24 Lug nut torque #3
HVAC,
Lug nut torque from op. manual:
Front: 110-132ft lb
Rear: 80-96ft lb
Matt.
I am far from home and have 2 flat tire's from dry rotted valve stem's.But one should not assume with out knowing the whole story.
   / BX-24 Lug nut torque #5
And had you given that piece of info I would have gladly given you the spec for a standard BX.:confused: Hope you get it going soon.:)
   / BX-24 Lug nut torque #6
My BX24 doesn't have any lug nuts....:confused::rolleyes:
Hey did everyone know there is a spot under the seat to keep the manual?
...and NO, I don't keep mine there either:D:D
   / BX-24 Lug nut torque #7
I thought that was a rag holder for checking fluids! That's what I keep there.
X2 for rag holder
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
LOT LOCATIONS (A51222)
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
