BX-24 Lug nut torque
   / BX-24 Lug nut torque #1
HVACDIESEL
What is the front and rear lug nut torque for a BX-24
THANKS
   / BX-24 Lug nut torque #2
THANKS
I do not have a bx 24; but is one to assume that you do not have a manual for the machine?
   / BX-24 Lug nut torque #3
HVAC,
Lug nut torque from op. manual:
Front: 110-132ft lb
Rear: 80-96ft lb
Matt.
I am far from home and have 2 flat tire's from dry rotted valve stem's.But one should not assume with out knowing the whole story.
   / BX-24 Lug nut torque #5
And had you given that piece of info I would have gladly given you the spec for a standard BX.:confused: Hope you get it going soon.:)
   / BX-24 Lug nut torque #6
My BX24 doesn't have any lug nuts....:confused::rolleyes:
Hey did everyone know there is a spot under the seat to keep the manual?
...and NO, I don't keep mine there either:D:D
   / BX-24 Lug nut torque #7
I thought that was a rag holder for checking fluids! That's what I keep there.
X2 for rag holder
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
Skid steer auger plate (A50322)
Skid steer auger...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
