BX-24 leaking o-rings on loader control
   / BX-24 leaking o-rings on loader control #11
Had the same problems, the stainless steel lines need to be replaced. Replacing the o rings just buys time does not fix it. There are threads on this and they are what used to show the dealer I was not crazy.
   / BX-24 leaking o-rings on loader control #12
This makes more sense ......:thumbsup:
   / BX-24 leaking o-rings on loader control #13
In this post, MacTractor says a design flaw was identified in his BX25.
I had a little trouble with o-rings in that manifold on my BX2350. Two different ones blew out. I suspect the second failed due to an improper repair of the first though.
I had my old BX22 do the same thing. Seems Kubota has an issue like the pedel sticking etc. grrrrrrr.
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR D3 CRAWLER DOZER (A60429)
CATERPILLAR D3...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
