Oil & Fuel BX 24 fuel guage not working
   / BX 24 fuel guage not working #1
kubotapat
Guntersville, AL
2008 Kubota BX24
I have a BX24 with 15 hours. Fuel guage stopped working - when key turned guage bounces from empty to past full and stays there regardless of actual fuel level. Any ideas?
   / BX 24 fuel guage not working #2
This problem was not uncommon on early BX24s. It will likely require replacement of the sending unit located on the fuel tank.
   / BX 24 fuel guage not working #3
Personally, I wouldn't try to repair this myself even if I knew what to do to fix it. I would call your dealer and have it repaired under warranty. This will also document the problem if the issue ever arises again. Too few hours on your tractor for this to happen.
Good advice, I was hoping to avoid having to haul to dealer but you are correct about having dealer take care of the problem.
   / BX 24 fuel guage not working #5
Thats cause by the gauge wire grounding out on the frame someplace.
Guage now working! My fuel guage is working, but is not at all accurate. Shows full until less than half tank.
   / BX 24 fuel guage not working #7
Same thing is going on with mine. Started at about 50 hours, I now have 70 hours on it. Not the biggest thing, definitely annoying. I check my fuel level before each use, so the chances of running empty are slim. I top off frequently. Wondering if they would send the sensor.
   / BX 24 fuel guage not working #8
My faulty fuel sending unit behaved in a similar fashion; it was replaced under warranty. It had apparently been damaged (rusted) by exposure to rain.
Note that the dash cluster was replaced under warranty on many early BX24s... also as a result of water damage; mine was replaced as well.
If you are having the fuel sender serviced under warranty, I encourage you ask the dealer to upgrade your dash cluster as well; Kubota claims that the new cluster will resist rain much better than the old.
JOHN DEERE 750 GRAIN DRILL (A58214)
JOHN DEERE 750...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
TANK MANIFOLD (A55745)
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
