Bx 2350 stalling on hill
   / Bx 2350 stalling on hill #1
99rt
central PA.
CUB 2072 SUPER
Hi I have a bx2350 seems when it is warmed up and I'm making it work down hill in forward with fel. it wants to stall when I try to back up I thought it might be low on fuel but when I filled it I had to squeez 3 gal. in it. It did this befor so I changed both fuel filters thought I solved it but that was only about 6 hrs. ago. any ideas ? thanks
   / Bx 2350 stalling on hill #2
Look into the seat safety switches. Most likely you are leaning to compensate for the angle and coming off the seat safety switches. might need adjustment
   / Bx 2350 stalling on hill #3
i agree...this happens a lot in either direction when i let my wife drive it because she's so short. it did it to me when backing up a hill too. I learned that was the problem and try not to shift my weight too often. haven't had to make an adjustment...yet
   / Bx 2350 stalling on hill #4
happens to me EVERY time i mow the same spot in my yard with a hill driving downward. Try driving down your trouble spot and purposely push down with your butt on the seat and see if it stalls.
   / Bx 2350 stalling on hill #5
I used to have this happen once in while. Now I use the seat belt when mowing. It keeps me on the seat better.
   / Bx 2350 stalling on hill #6
I agree with the saefty switch issue. It is normally very sensitive.
   / Bx 2350 stalling on hill #8
I found and removed one of the 2 "Z" shaped spring plates on the seat switch when I still had the old style seat. You did't mention if you had or not, but make sure you have the new style seat, it is shaped to better keep you from sliding forwards.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
20' Sea Container (A50774)
20' Sea Container...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
1269 (A50490)
1269 (A50490)
2016 KUBOTA SVL95-2S SKID STEER (A51242)
2016 KUBOTA...
