Oil & Fuel BX 2350 Front Axle Oil
   / BX 2350 Front Axle Oil #11
From what I understood they are shipped with gear oil not SUDT. Is this wrong? Mine was low and I topped it off with gear oil. Hopefully his is better than just low fluid?
   / BX 2350 Front Axle Oil #12
Unless something has changed very recently - BX ship with SUDT in the front axle... Any else heard different?
I added about 1 qt to my new BX2350 after about 10 hrs of use... And I did change it out during my 50hr service - looked clean, probably wasn't necessary, but I always change fluids early on any new vehicle...
   / BX 2350 Front Axle Oil #13
All of mine have had SUDT up front when delivered.
   / BX 2350 Front Axle Oil #14
SUDT when delivered (June 08) in mine also.
   / BX 2350 Front Axle Oil #15
I have UDT in mine haven't had any problems, but when its time to change it
I think I will go with gear oil. Front axle oil was low to when I got it from the dealer too.
I wouldn't cause it means keeping 2 types of fluid on hand instead of just one.
   / BX 2350 Front Axle Oil #17
I was told mine had SUDT in the front axle when I went to buy extra oil for topping off the front axle, transmission and engine oil. Service mgr said stick with SUDT unless I get seepage, then change to gear oil which is heavier and less likely to get by the seals.
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2014 Freightliner 108SD Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
