BX 23 won't turn over?
/ BX 23 won't turn over? #1
TheWeis
BX23
Hi All,
Please help. ran fine for about an hour yesterday, turned off, now it won't turn over.
fuses all check good, fuel pump, block heater and starter solenoid run when key turned.
Any help greatly appreciated before I turn it in to be serviced.
PW
/ BX 23 won't turn over? #2
1st make sure your pto is disingaged
Put trans in nuetral and jiggle the lever
Lift up seat and see if your seat safety switch has come loose...or over ride it temporarily by putting a piece of cordboard or wood between the small lever and the contact point.
Check the engine ground to the battery.
Let me know
Frank
/ BX 23 won't turn over? #3
If what Frank says does not work, do it all over again. Frank's tips cover 99% of all issues with starting (besides the obvious dead battery!)
You can check the battery condition by turning on the lights when you try to crank it. They would normally dim a bit when you turn the key. If they go dark, the battery is toast (or the connections). If the lights stay bright, something is stopping the tractor from supplying juice to the starter solenoid.
Vermeer 6020 3 Point 8ft. Disc Mower (A65640)
Vermeer 6020 3...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
(2) Vermeer 9255 Tracks (A66408)
(2) Vermeer 9255...
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
30x57 Welding Table (A65640)
30x57 Welding...
