bx 23 tire replacement suggestions
   / bx 23 tire replacement suggestions #1
tommu56
Elite Member
Lycoming county pa
kubota bx23
For the umphteen time I got a flat this weekend on the rear of my bx23.
It was spitting slime out a big hole as I was putting it away. I jacked it up and spun the hole down to the bottom and put a jack stand under it.
Has any one else went with a "heaver" tire the shale I have keeps putting cuts in them usually by the lug base and I put the big patches on the inside after cleaning the slime off but sooner or later I will need new tires.
I was thinking heaver ply rating but dealer said that doesn't necessarily mean more puncture resistance?
any suggestions?
tom
   / bx 23 tire replacement suggestions #2
I am interested in finding a more robust tire. Kind of shoots the whole day... getting a flat.
I'm thinking about going with a liner and tube the next time around...
So far, I've found it cheaper to order a complete tire with rim through Kubota "Whole Goods" at my Dealer.
   / bx 23 tire replacement suggestions #3
What tires are you using now? I'd suggest getting a set of industrials.
   / bx 23 tire replacement suggestions #5
I had alot of trouble with flats on my BX23 from glass, nails and shale also. I foam filled all 4 tires and no problem since. I also bought another set of tires and rims for just air filled tires I need them. Cost a few bucks but worth it.
Glenn
   / bx 23 tire replacement suggestions #6
Plus one for the foam-filler. Zero problems snce filling, plus lots of extra weight. Dave
   / bx 23 tire replacement suggestions #7
Does the foam filled tires ride rougher ?
I foamed the tires on a finish cut deck once and they seemed to jar around a bit more.
   / bx 23 tire replacement suggestions #8
They do ride rougher but if I do not need the foam fill protection I switch to my air filled ones for a better ride. The extra weight does help alot with the foam.
Glenn
Cyberknight
How mutch did it cost?
Were did you get it done?
I am just out side philly
tommu56
   / bx 23 tire replacement suggestions #10
Hi Tommu56
I paid about $400.00 to have all 4 filled. I went to a large tire place (Highland Tire in Allentown, Pa) and they sent them out to be filled. They had different hardness of fill and I got the hard stuff. I think they do fork lifts this way also. I would imagine any large tire place could tell you who could do it.
Glenn
SKID STEER ATTACHMENT RAKE (A58216)
SKID STEER...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
(2) Seats (A57149)
(2) Seats (A57149)
2013 John Deere 245G LC (A55272)
2013 John Deere...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
