Mowing BX 23 Mowing with FEL & BH attached
   / BX 23 Mowing with FEL & BH attached #11
</font><font color="blue" class="small">( If the BX23 is like the BX22, with the BH mounted, you can not fully lower the mower dect. The 3PH arms in the back hit part of the frame of the BH and only allow partial lowering of the 3PH, which is used to lift/lower the mower deck.
As for mowing with the loader attached, you can do it, but I found that the ucket sticking out in the front seriously limited the ability to get in tight when mowing around things like trees and bulidings. You can get close if you are slow and careful, but for the few minutes that it takes to remove the BH and FEL, it was not worth the hassle.
On the contrary, with the deck on, and fully raised, you can attach the FEL and BH and use them. The big hassle is driving around the dirt and hitting the deck with the dirt.
paul
)</font>
Agree 100% with all points. As easy as the FEL and BH are to remove, why not? Part of the reason I ended up with a BX23 was that it's like the Swiss Army Knife[tm] of CT's.
   / BX 23 Mowing with FEL & BH attached #12
</font><font color="blue" class="small">( What! There is another way? )</font>'
Mowing the lawn with the backhoe and loader attached is like taking a shower with your clothes on..... You will get wet, but you will still stink when you get out.../forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX 23 Mowing with FEL & BH attached #13
</font><font color="blue" class="small">( </font><font color="blueclass=small">( What! There is another way? )</font>'
Mowing the lawn with the backhoe and loader attached is like taking a shower with your clothes on..... You will get wet, but you will still stink when you get out.../forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
<font color="#666666">Works fine for me like I'm doing it so why bother playing musical implements?
I can use
1 Two mowers
2 Tiller
3 BH
4 FEL
5 Dirt blade
without adding/removing or changing attachments/implements.
So why should I start doing so? </font>
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2007 Ford F-750 (A55973)
2007 Ford F-750...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
