Bx 2230 hyd fel valve
   / Bx 2230 hyd fel valve #1
Scottiboy
Kubota BX2230
hope someone can help me out. I have a bx2230 with a la211 fel. I built a 60" snow plow with double acting cylinders(8"x1") for lift and angle. My problem is when i angle the plow to the right it will automatically swing to the left if you dont push past the detent in the valve. when i have the loader on this is not an issue. could it have something to do with the size of thwe cylinders i am using or can i adjust the detent in the spool? Thanks ahead of time for any info you can give.
   / Bx 2230 hyd fel valve #2
Here's a post that may shed some light on your problem?!?
Jim
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
UNUSED LONCIN 90 PLATE COMPACTOR (A51248)
UNUSED LONCIN 90...
