BX 2230 3 point hitch won't raise
   / BX 2230 3 point hitch won't raise #1
RacerX10
Russellville, AR
Kubota BX / Long / Yanmar EX 3200
Have a BX 2230, when I parked it at the end of last season the 3 point hitch was working fine. Was getting it all ready to use this season and the 3 point hitch initially would only raise very slowly (and kind of stuttering / jerky), now it won't raise at all. Hydraulic fluid is at the correct level. The speed control knob under the seat doesn't seem to make any difference, in any position from one end of the range to the other. Tractor RPM doesn't seem to have any effect either.
Where do I start ?
Thanks !
* UPDATE. If I work the steering back and forth, or at full left or right travel, the 3 point hitch starts working ??? (slowly). I was able to raise it up by messing with the steering end to end .. how in the world are they related ? Also, is 90 wt gear oil the correct fluid to fill the @ the right front axle check point ?
   / BX 2230 3 point hitch won't raise #2
Check to make sure your hoses are correct if you've taken the loader off.
No hose changes, don't have a loader
   / BX 2230 3 point hitch won't raise #4
First thought was the same that some how the hoses got reversed. Moving on, I would be checking all my hydraulic lines because it sounds like air in the system.
BX2230 front axle oil change
Kubota UDT (expensive stuff!) or 80/90 wt. gear oil.
Not sure why but it's just started working again on it's own.
<sigh>
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2006 Nissan Titan Crew Cab Pickup Truck (A50323)
2006 Nissan Titan...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
