Will_C
Veteran Member
- Joined
- May 24, 2002
- Messages
- 1,787
- Location
- Upstate N.Y.
- Tractor
- Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
I was doing some spring cleaning today with the tractor (throwing stones from the lawn into the FEL, raking ditches with a landscape rake, etc.) I stopped for a drink, shut the tractor down, and started it 5 minutes later. I had virtually no steering. Two or three complete turns of the steering wheel would crank the wheels about 10 degrees.
I suspected a blown hose, and climbed off the tractor to check. Nothing. I raised and lowered the FEL and the 3pt hitch. They worked fine. The transmission worked fine.
I tried raising and lowering the rpms and the steering did not respond. I made sure that the 3pt hitch control was in neutral, and the FEL was stationary.
I loaded the tractor onto the trailer (I was working at my Mother's) and returned home. When I unloaded the BX, I had steering!! I took the tractor into the garage and did a complete inspection of the underside-no leaks, not one drop of UDT.
I then raked my gravel drive for 30 minutes.The steering worked fine. Some of the steering was gentle turns, some under a load (pulling a rake full of stone dust, in 4wd, etc.)
I am at a loss. Any ideas what shut the steering down?
Thanks,
Will
Thanks,
Will
