BX 2200 Steering Piston Help
   / BX 2200 Steering Piston Help #11
Alright, I got the kit, and want to attempt to order the o-ring that leaks to have spares on hand, and let others know what to get rather than buying the whole kit. Which o-ring is it? There appears to be three sizes?????:confused2:
O-rings are cheap (well, compared to most other parts and time) , so it probably makes sense to replace them all if you are taking the time to open it up.
   / BX 2200 Steering Piston Help #12
I am reading that there is one that fails usually.....Just trying to help with the info.:thumbsup:
And as far as cheap, the kit was $44 and a failure occured at just over 400 hours.....Not a good ratio.:mad:
   / BX 2200 Steering Piston Help #13
You might find some O rings that will work, but what about the seals? Some are internal and are double lipped.
   / BX 2200 Steering Piston Help #14
In reading the posts about this repair.......It has been said several times that there is one o ring in particular that usually fails......Hence you could repair this for a few dollars instead of $44 if you had the info on the ring that fails to buy just it.
   / BX 2200 Steering Piston Help #15
It is a metric oring, but measures 1.330" ID and 0.120" cross section. Hopefully that matches one in your kit. My measurements are from a BX1500 steering cyl oring. The Oring goes on a collar in the middle of the chromed rod. When you do the work look for a small hole that is provided into the circlip groove to aid removal of circlip. You only have to open one end.
larry
   / BX 2200 Steering Piston Help #16
larry
Thank you!!!:thumbsup:;)
   / BX 2200 Steering Piston Help #17
Just finished mine this last weekend. Started taking it apart, went to the computer to look up info and computer crashed.. bad timing.
Finished it anyway on my own - took about 2 hours. 1200 hours on machine and back like new. My lawn will have straight mow lines again.
The middle o-ring was flat not providing a tight seal anymore. I had the kit, so I replaced all the o-rings & seals. The wiper seals were hard to get out and the blue inner lip seals were a PITA to get out & in, but all ended well.
   / BX 2200 Steering Piston Help #18
How many hand injuries did you incur? I finished at around 5.....:laughing:
Good job!!!!:thumbsup:
   / BX 2200 Steering Piston Help #19
FINALLY ran across word of a kit! Could someone please provide the kit # and where you can get it? My local dealer keeps pushing a new cylinder for $700? Please help. Thanks!
   / BX 2200 Steering Piston Help #20
The O-ring is what goes bad. Buying the kit wastes several tens of $.
larry
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
Coats 40-40SA Heavy Duty Air Powered Tire Wheel Changer (A54816)
Coats 40-40SA...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
Case Backhoe (A55973)
