BX 2200 shut down after 3 minutes won't start solved!
   / BX 2200 shut down after 3 minutes won't start solved! #11
Its the fuel sending unit under the left ROPS, Its a known problem ask the dealer abut it. I just fixed one last summer, basically its a crap deign of the gasket. the new sending unit is totally different design. The main Problem is the sending unit is recessed into the plastic tank allowing grass, dues/dirt and lots of water into the Tank, you will understand once you see it. I did every thing to figure this out and the gasket was the last part to check. basically you disassemble ROPS, seat, fenders, floor pan. Its a PITA job fut i got the power washer out and its like a new tractor.
Toledo is right, I think. Many if not most older BX owners have filled the tank and found the fuel leaking out. I can't fill my BX2200 more than about 2/3 of a tank without fuel leakage, esp when it sloshes around but if really full it leaks sitting still. Not worth it to me to disassemble the tractor that much to fix/replace the sending unit but numerous people on TBN have reported the problem.
And since I keep mine in a garage the water seeping in to the fuel is never an issue....
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
