bx 2200 lights added
   / bx 2200 lights added
Right now they are attached with 3M foam tape. If I stay happy I might fasten them with over size pop rivets. I've used the tap on many thing in the past and haven't had that part fail so we'll see what happen if I was worried about them as a hand hold or really banging around the terrane some of you guys have I'd have to go with thick steel and a welder!!
With my 240lbs doesn't take much to make the aluminium think my way...
Thanks for the compliments!
Seems like it took longer to figure out what to do than to do it.
Sorry, I forgot to mention I used the wiring that came with the lights to go to the box and in the box is the 15 amp fuse that came with the lights. The plug under the seat uses the "ignition on" hot lead that the kubota had from the factory just clipped the ends to attach the other plug.
Cheers
Tony
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
(2) SHOP VACS ON PALLET (A58374)
(2) SHOP VACS ON...
2013 Ford F-250 (A56858)
2013 Ford F-250...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
