BX 2200 HST light on
   / BX 2200 HST light on #1
nbennett
West Virginia
Kubota BX2200
My next door neighbor's BX2200's HST light came on when she started the engine. The hour meter doesn't work so she doesn't know how long its been since the transmission oil has been changed. I checked the oil level and found it OK. This evening I changed the oil for her, replaced the filter and cleaned the screen. The screen had quite a bit of metal shavings but was by no means stopped up. I put in about 2.7 gal. of super UDT. It comes to the upper mark on the dipstick. The HST light is still burning even after I let the engine run at slow speed for several minutes. Any ideas?
   / BX 2200 HST light on #2
nbennett The light should never come on because it is not hooked up to anything. My first guess would be that someone grounded the wire that would be hooked up to a sensor if it had one.
For more info check this thread out.
HST light
That makes sense because she told me someone in her family had recently fixed the lights. Thanks. I will pass this on to her.
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2013 CATERPILLAR D5K2 XL CRAWLER DOZER (A52705)
2013 CATERPILLAR...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
