bx 2200 hood rattle
   / bx 2200 hood rattle #1
rrwitt
I have had the tractor for 2 years and just noticed a noise
from the hood. Seems the hood latch opening is worn a little
and at idle you can see the hood vibrating and when I hold
the hood down against the probe which mates to the latch the
noise goes away. Any fix for this?
   / bx 2200 hood rattle #2
I just used some of that foam window sealing tape that comes in rolls. I used the 1/2" wide stuff. I cut two pieces to run the full length of the hood, one on each side. No more rattles, cost was like 2 bucks.
   / bx 2200 hood rattle #3
no more air circulation either
   / bx 2200 hood rattle #4
<font color="red"> no more air circulation either </font>
What are you talking about? The air gaps between the hood are not for air circulation. The BX uses a reverse mounted radiator and the hot air escapes through the front of the tractor.
   / bx 2200 hood rattle #5
rrwitt --Well Welcome to BX country. They should supply ear protection when you buy a BX22 or BX2200. I did a search and found the best fix was to push in the side. Not too hard it will buckle (I did that and had to fix)...easy though.
This works mint! I guess I did not have the hood raddle when new but, since my dealer said I have a broken air filter bracket. Once he fixed that i had the raddle of death. So i had to fix the hood. THERE WAS NO WAY I COULD LIVE WITH THAT.!!!
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
1990 PETERBILT 320 HYDROVAC (A53843)
1990 PETERBILT 320...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Equipment Trailer (A53117)
Equipment Trailer...
