BX 2200 help
   / BX 2200 help #21
Well DaveL.........Here's the best I can tell ya. All 3 units arrived Sat., but I havn't had the time,or weather to play yet. So, to answer some of your questions, GBC48 weight,285#, and it raises higher than 3-4" although I forgot to measure it while it was on. Built wise, looks like it will handle anything that the BX will give it. /forums/images/graemlins/shocked.gif
LRC60 Rake. Again, looks fine. Don't know about the springy tine thing though till I try it. /forums/images/graemlins/tongue.gif
RBC60 Blade. Nice fit. Raised full height about 16" from ground. This will vary about an inch depending on the top link adj., but much better height than the RB60. Does not tilt but was not a issue with me. Also it will rotate 360 while all the way up. /forums/images/graemlins/laugh.gif
Remember no play time yet /forums/images/graemlins/frown.gif Negetive so far, only 1 hitch pin for the blade and rake, will get another one for each. /forums/images/graemlins/mad.gif Note the dealer did put the lower link pins on the inside which was fine. The pins may work ok on the outside too but it works for me this way.
So far.......Great for fit, good paint, good welds, built nice. /forums/images/graemlins/wink.gif
George
   / BX 2200 help #22
Pemad,
Raised Back blade today, RBC60 Woods. 16" from ground. Hope that helps. George
   / BX 2200 help #23
kuborange,
Will do but can't do it until this weekend. I can say my BX can lift it of the ground fairly high. It really all depends on the top link adjustment.
pemad
   / BX 2200 help #24
ges,
Thanks for your reply. Still waiting for my GBC. Sounds good. I think I'll get the woods rake after looking over some of the replies in the attachment forums. The dealer has a couple on his lot ready to go.
Its only money (right????) /forums/images/graemlins/grin.gif
Thanks again,
DaveL
   / BX 2200 help #25
kuborange,
I went out and hooked up the BB to the Bota and I can lift the blade up around 16 inches off the ground with my current top link setting. I hope this helps.
Dynapac CC122 Smooth Drum Roller (A57453)
Dynapac CC122...
JLG 660SJ (A58216)
JLG 660SJ (A58216)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Transit Cargo Van (A56858)
Transit Cargo Van...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
Hercules Safe (A57149)
