Oil & Fuel BX 2200 Gas Tank Leaking
   / BX 2200 Gas Tank Leaking #1
keepscouting
Bardston, Ky
Kubota BX2200
I have been looking thru the forums and have found many post for the dreaded leaking gas tank on a Kubota BX 2200 tractor. If the tank is filled over 1/2 way it will leak on the left hand side. The links seem to be dead within these posts and I wondered would any have links to what parts and if they exist steps or how-to-videos on making this repair?
Thanks in advance.
   / BX 2200 Gas Tank Leaking #2
That was subject of a recall. Try your dealer as they may still honor as it is an environmental concern. When I had a 2200 they came to my house and fixed it but I wasn't there so I don't know what they did but was told it takes but a few minutes
   / BX 2200 Gas Tank Leaking #3
It has been a few years since i had that problem & there was a fuel sensor & gasket kit that had an improved mount on the fuel tank. I cannot remember the part numbers exactly, but try
Sensor, Fuel K2561-61370 & Gauge Gasket 6A100-54790 Kubota dealers should be able to reference a part number if this doesn't match up.
Also try part # K2561-96132
Thank you both for the information. I will call the local dealer tomorrow and post back if they cover it under warranty etc! Really appreciate the help and information.
   / BX 2200 Gas Tank Leaking #5
For what it's worth I received my kit about 8 or 9 years ago & it was covered under some sort of recall. After this amount of time you may want to call Kubota headquarters customer service & see if they will still honor a replacement.
The dealer said this was never part of a recall or replacement...it cost me about 25 dollars and a few hours of time. I ended up having to use some gasket sealant in order to stop all the leaking even with the new part but now I have a mower that's not leaking at least. I wish I could leave someone tips and tricks to make this easier on them, but I don't have any and hope I don't have to repair this again lol...Thanks again for everyone's input.
   / BX 2200 Gas Tank Leaking #7
For what it is worth, the dealer is full of BS. No reason to pursue it, however. It is fixed and probably better than the dealer would do.
You may want to be careful about relying on the dealer.
   / BX 2200 Gas Tank Leaking #8
Agreed...sounds like the dealer is not one to go the extra mile. Think I would be trying to find someone else to use!
   / BX 2200 Gas Tank Leaking #9
Is there an online resource to find recalls on tractors like there is for Autos.
   / BX 2200 Gas Tank Leaking #10
So, what exactly did you do and what did you need to buy? I recently bought a BX2200 that has the same leak above 3/4 talk, as per the PO. I've been filling it to 3/4 and haven't experienced a leak, but it is allegedly there - might as well fix it if I can, since I hate having to worry about over-filling. Please elaborate - thanks.
TAKEUCHI TB235-2 EXCAVATOR (A52709)
TAKEUCHI TB235-2...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
