BX 22 with Tiny Tach
/ BX 22 with Tiny Tach #1
Jimbrown
Tombstone Az
KIOTI LK30
What RPM do those of you with Tiny Tach get at idle and full throttle. Mine seems to idicate fast but I have no way to test it or calibrate it. I get 1280 at idle and 3360 at full throttle.
/ BX 22 with Tiny Tach #2
I wish I could help you there. Mine doesn't even have one. Probably not necessary, but I'd like to have one anyway. (B6100 HST-E)
/ BX 22 with Tiny Tach #3
I'd like to help you, Jim, but I whacked my TinyTach with a fence rail that fell off the FEL a couple months ago and have to replace it...the display is trashed. But if my memory serves me, your readings are't far off from what I get on my BX22.
/ BX 22 with Tiny Tach #4
I'll run mine tomorrow and let you know idle. I'm not to 50HRs yet, so don't know full throttle yet.
Ron
/ BX 22 with Tiny Tach #5
I have a BX2200 and no tach. I also have a B2910 with a tach.
When I mow with the BX, I just put the throddle full on (now have over 50 hours) and mow.
When I do other things with the BX, I just set the engine speed by ear.
So I have to ask, what does the tach on the BX do for the operator? I am not sure if I even need the tach on my B2910 actually. I do use it to set RPM at "550" for my rotary cutter, but other than that I never run at full PTO rpm anyway....
AT this point in time I don't know if I want to bother with a tach on my BX at all. And I am pretty sure I don't, actually...
/ BX 22 with Tiny Tach #6
But Henro, it looks cool--like a bigger tractor!
I can't believe you don't want one.
Ron
/ BX 22 with Tiny Tach #7
Don't forget to remind Henro that it gives him another chance to drill holes in his tractor!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ BX 22 with Tiny Tach #8
On my 2200 that sounds about right. The idle seems fast but mine has always been that way. I normally mow between 1900 and 2300. Blowing snow I run at full speed and you know, I have never looked at the tach when I an blowing snow....guess I just figured that full speed was full speed...next winter I'll remember to look and see what the rpms are!
/ BX 22 with Tiny Tach #10
I understood that you ALWAYS run implements at full throttle on the BX, since that is the correct RPM for the PTO. I cut at full throttle, find that less usually does not cut as good. Tilling, full throttle does so much better with my clay soil anyway. I have a KK 48" about as big as you can get for this size tractor.
/ BX 22 with Tiny Tach #11
I was running my 2200 today. Cold start (90* outside) it ran at 1300 at idle.
Can't help you on full as I've not run it there yet.
I mowed some with my MMM and 1900 does fine for me (lawn type grass). Loader and 52" tiller do fine at that speed as well. When I get 50+ hours, I'm hoping to get more umph in my box blade.......
Hope this helps.
Ron
/ BX 22 with Tiny Tach #12
I use my Tiny Tach all of the time. I engage my PTO at 2000 RPM and I usually run my MMM and Tiller at 3100 RPMs, which is less than full throttle.
540 rear PTO speed = 3068 engine RPMs.
2500 mid PTO speed = 3125 engine RPMs.
John
/ BX 22 with Tiny Tach #13
The tiny tach in a magnetic pickup type deal. You bolt the sensor over an injector line and wire it to the Tiny Tach and your battery.
I have no clue how it works, but it seems to.................. Magic I guess.
Ron
/ BX 22 with Tiny Tach #14
<font color="blue"> Is this tach cable-driven or electric? </font>
It has a transducer that goes around one of the injector lines, and it senses the pulse when fuel is forced into the cylinder. So I guess it would be electronic... /forums/images/graemlins/smile.gif
Jitter Bug (A62613)
Jitter Bug (A62613)
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
John Deere 6105D (A64126)
John Deere 6105D...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
