BX-22 White Smoke won't run
   / BX-22 White Smoke won't run #1
MikeLad61
Orange County, NY
Kubota BX-22
BX-22 White Smoke won\'t run
I was using my bota all day cleaning out a greenbelt using the hoe to grab piles of branches and dragging them to a burn area. Ran the machine about six hours no problem. I had it set up to use the backhoe to push a tree I was cutting. I had the chain saw running and I had a helmet with hearing protection on. I saw "white smoke" and heard the bota sputter. I ran over and can't remember if it shut down or if I shut it down. But it won't start. I have 125 hours on the machine and all the maintenance has been done religiously. I will try starting it in the morning. I had to leave for Boy Scout meeting. Any info will be appreciated. Good thing it's under warranty. The wife is not happy as I told her Kubota is a very reliable machine and you usually pay for what you get.
Thanks,
Mike /forums/images/graemlins/frown.gif <font color="yellow"> </font>
   / BX-22 White Smoke won't run #2
Re: BX-22 White Smoke won\'t run
Out of fuel????????????
   / BX-22 White Smoke won't run #3
MikeLad61,
1.Out of fuel (sounds dumb but just to be sure)?
2. Overheated?
They will pop a little smoke if they are out of fuel (I guess enough fuel being injected to make a little smoke but not enough to fire the mixture).
Good luck and keep us posted on what happens.
BTW, welcome to TBN.
DaveL
No the fuel is ok. IN fact I filled up about one hour before this happened. I thought maybe I had water or a bad patch of diesel fuel so this morning I drained the tank and both fuel filters and primed the system to no avail. The motor turns over but it just doesn't seem to get any diesel. I at my wits end and I'm about to phone the dealer. Thanks for the help and I'll let everyone know what happens.
Happpy Easter,
Mike
Well I called the Pine Bush Equipment and left a message on voice mail. I no sooner finish leaving the message and the phone rang. The service manager Bob was returning my call. I let him know I purchased my bota out of State. He had no problem with that. He did inform me after bring him up to speed about my problem that there would be a service fee if they came out. He believed the problem was fuel related. Either I ran out of fuel or a clog had cause the bota to run out of fuel. They had a mechanic at my house in half an hour. He cracked the flare nuts on top of the injectors to bleed out any air, except there was no fuel. We took off the front guard and bonnet to access the motor. He checked the electrical to the fuel solenoid and it was getting power. When he did a visual inspection of the fuel solenoid he noticed a bulge in the back plate. He said the solenoid looks like it overheated. Sure enough he started the bota up by bypassing it. Unfortunately, PBE didn&#8217;t have one in stock. This part was a first for the mechanic and the parts guy on a BX-22. The part should be in Monday and with the Easter weekend I won&#8217;t be getting any seat time anyway.
Thanks for in help and Happy Easter,
Mike
/forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / BX-22 White Smoke won't run #6
mike,
Sounds like the fuel solenoid coil had a bad spot in the wire insulation and shorted (or some such). Good to hear that it was not something major. BTW, how did he bypass the solenoid if it was burned open?? Sounds like a good thing to know should the need arise.
good luck,
DaveL
   / BX-22 White Smoke won't run #7
glad u got the problem solved, but how did he bypass the solenoid? does it have a manuel jack open screw on the bottoem?
He took it out and ran the bota without it. The solenoid has a plunger on it in that sticks out and hits something inside the injector pump. He was willing to set it up to run and told me to shut it off all I would have to do is move either the governor or speed control lever. He would also have to cut the plunger off so no contact inside the injector pump would take place. I thanked him and told him I didn't need to use the bota that badly. I was worried about warranty issues. My luck something else would go and the warranty issue pops up.
Mike /forums/images/graemlins/smile.gif
   / BX-22 White Smoke won't run #9
Well I think I have the same problem. Was fertilizing the lawn and the tractor just died. Fuel was between ¼ and empty. I figure it ran out of fuel. Fill it up, NO LUCK. It runs when you turn the key, as long as I hold the key it will run, as soon as I let go it stops! Checked the PTO and shifter, they are OK I can get it not turn over when they are in the wrong position. SOOOO what do you think?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Tractor has 106 hours on it. The dealer is 2 hours away I am sure he is up to his eyeballs with work. AND I just fertilized the lawn, you know what I will need to do in about 5 days. AND off on a business trip this PM for 3 days AND the tarctor is at the back of the property. If I put it in N can I pull the tractor? Gee first the wrong blades on the deck and now this, who did I piss off??
When it rains it pours /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
   / BX-22 White Smoke won't run #10
You might have to bleed the fuel system.
Egon
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
LMC G300JD LOT IDENTIFIER 230 (A53084)
LMC G300JD LOT...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
