Mowing bx 22 mower pto u joint
   / bx 22 mower pto u joint #11
When you press on one cap, the cross bearing should push the other cap out of the yoke completely. Then you turn it over and push on the other side of the cross bearing through the hole in the yoke where the cap was removed. I don't understand why this won't work for you. If it doesn't come out then, try using a vice grip to pull it out the rest of the way. I took my deck off, and I notice that you need to remove the grease fitting before removal of the cross bearing.
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
Push Mower (A55973)
Push Mower (A55973)
