dieselbob69
Hey folks,was wondering if anything like this has happened to you. I was mowing(BX 1870), turned PTO off to go pick up item in the lawn,left it at around 2500+ rpms, and as I was picking the item up in lawn,the tractor rpm's went to idle . When I got back in seat and pulled throttle lever down,as soon as I let go of it, it went right back to idle, it won't stay put. I finished the last 45 minutes w/ me holding the throttle down by hand. I was able to look at it when I put it in garage,cable still actuates the lever on pump,but it springs right back to idle when released. It looks like there is a small hole a small spring would hook into,but I don't see another hole. I don't know if a spring broke or not. I see the adjusting nuts for the throttle that has a piece of thin cable wire wrapped around them w/ the ends crimped together(? for dealer to see if you've messed w/ pump idle settings so they can deny warranty for any problems?). I only have 80 hours on this machine and it's had multiple minor issues since purchase,this is the latest issue. I'm starting to get disgusted w/ Kubota once again.....thinking I shoulda spent a little extra and gone green......
