BX 1870-1 ROPS bolt
/ BX 1870-1 ROPS bolt #1
Amf232
Mass
JD 318
I was removing the nut off the ROPS bolt, the one on the bottom that goes into the fender. And one stripped out pretty badly. Does this bolt come out too or will I have to get a die and rethread what's left? Also what size is the bolt? I know it's metric I'll try to attach a picture of the mess I made Thanks T
/ BX 1870-1 ROPS bolt #2
I checked on my bx 2370-1 and the bolt would come out the bottom, but the fuel tank is in the way of removing it from the bottom. I'm guessing yours is the same. So if you want to replace that bolt it looks like you would have to move the fuel tank out of the way, yikes. Hopefully there is an easier way to do this if you wanted to replace the bolt but I'm not sure.
Are you not able to get the nut back on? How did you strip it like that?
I don't know how it happened. Put the impact on it. Zip zip stuck half way. Would not go back on or off so it was stuck in the middle which was pointless. So I forced it off with a big ratchet.
Any idea what size? M14?
/ BX 1870-1 ROPS bolt #5
I think M14 but not sure what thread pitch.
/ BX 1870-1 ROPS bolt #6
Why are you taking the nuts off? If you want to part with your ROPS I am willing to pay a good amount of cash for it. PM me
/ BX 1870-1 ROPS bolt #7
Make sure once replaced you use some anti-seize when putting it back on.
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
CATERPILLAR PC306 QUICK ATTACH HYD PLANER (A60429)
CATERPILLAR PC306...
APPROX (20) 9'-3"X3" SQUARE TUBING (A60432)
APPROX (20)...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
