BX 1850 Hydraulic connection help
   / BX 1850 Hydraulic connection help #1
scarlo101
Ontario, Canada
Kubota BX 1850, NH TN75
Hi all.
Iam trying to plumb a 4 way husco FEL valve to my BX. Attached are some pics of my tractor and the valve Iam trying to connect. Also included is a pic of a new tractor line connection with the ports marked A, B, & C. What I need to know is which port from the tractor goes to which port on the valve. 2 of the ports on the valve are marked in and out. I do have the block to mount onto my tractor as well as the hydraulic lines.
Thanks in advance for your help.
Anyone able to inspect their FEL valve connection.
Thanks
   / BX 1850 Hydraulic connection help #3
scarlo101, Here is a hyd schematic and a loader valve block valve info sheet. I hope this helps. I all so have a sheet on the Aux. hyd. valve install but I would have to scan it.
  • 88559d1194035091-extra-hydraulics-bx2350-hydraulic.pdf
  • 88564d1194036880-extra-hydraulics-bx2350-hydraulic2.pdf
   / BX 1850 Hydraulic connection help #4
Using your posted picture, Port C would go to IN on your valve (power). Port A would go to OUT on your valve (return). Port C is the drain (to tank). Again hope this will help.
Action,
Thanks for your help. I will be connecting this valve in the near future.
   / BX 1850 Hydraulic connection help #6
Glad I could help be sure to post some pics. when your done.
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53472)
2016 Ford F350 -...
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
