MIKE_E
I finally got to put the little 1500 to work last weekend. I had to help cut up and move around some downed trees. We had a tree partially hung up on another, so I thought I would give it a push with the BX. The ground was soft loamy covered with grass so I had a good grip. LOw range, 4WD, wide open throttle. I got the bucket up to the tree and gave her the beans. The tree moved a little bit and there I sat, I thought maybe the tires were spinning and digging in but that was not the case. The motor was working but there was not enough power to the wheels to even spin the tires. /forums/images/graemlins/mad.gif I wouldn't have thought a whole lot about it but later in the day we dragged a log out of the brush in "reverse" that was almost a big as that tree with no problems. /forums/images/graemlins/grin.gif
I would have thought this little thing could dig itself in, right up to the axles if you gave it a chance. It will spin the tires on and dig in on my gravel driveway.
Am I expecting to much out of this little brute or does anyone think I might have a hydraulic problem? /forums/images/graemlins/confused.gif
Only 20 hours on the machine.
Thanks Guys
Mike
Thanks Guys
Mike
