Grading bx 1500 box blade
/ bx 1500 box blade #1
oledocward
north carolina
kubota 2350
can anyone compare woods and king kutter 48 inch box blades in terms of price, quality, functional characteristics, etc.? thanks
/ bx 1500 box blade #2
Not a reply to your specific question but I wanted to mention that I have a 2410 with a 60" box blade and also a BX2200- a bit heavier and more powerful than your 1500.
The 60" is about maximum for the 2410 and I would think a 48" would be a stretch for my 2200. I think you might want to consider a 42" for the 1500.
/ bx 1500 box blade #3
I agree. I use a Land Pride 42" box blade on my BX1500 and would not want anything any bigger. The Land Pride is tall and quite heavy though. maybe a lighter model would allow you to go wider. My neighbor has a Gilmore box on his BX2230 that looks much lighter than my blade.
/ bx 1500 box blade
thanks for the info regarding blade size for my 1500; the smallest box blade I've seen advertised here in NC is 48 inches. I have a 60 inch back blade that the tractor seems to not have problem with. But I don't want to buy something that is too much for the tractor. anyone else with a bx1500 and box blade with info is appreciated.
/ bx 1500 box blade #5
I also have a 60' back blade for my BX2200 and I agree that both of our tractors can handle that fine. The box blade is a very different animal, though. It weighs probably 2.5 times what the back blade weighs and can really gather up dirt/gravel. I have had so much behind my 2410 that the hydraulics would not lift the blade when the dirt did not immediately fall out.
Kubota makes a B7542.
/ bx 1500 box blade #6
Box blades vary greatly in weight.My 48" bb weighs 565lbs.Northern tool has a 6 footer that weighs 515lbs.I have a 2230 and wanted the heavier blade for the extra ballast when using the fel.I agree a 42" bb would be better on a BX1500.
/ bx 1500 box blade #7
I have a 48" KK "XB" Box Blade on my bx1500. I believe it weighs around 300#. My bx1500 Operators Manual (p.5 implement limitations) lists maximum weight for a box blade at 375# and maximum cutting width at 48", so it is within spec.
I have used the BB for grading gravel as well as for some digging and levelling rough areas. I think the "XB" works fine on the bx 1500 for light scraping and levelling, but digging pushes the limits of its capabilities, IMHO.
I bought the BB mainly for counterweight for the FEL, but have also found it useful for the other purposes I mentioned.
The nice thing about the 48" width is that it covers the width of the tractor, so you're not running over your work.
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
(3) Pieces of 30' Sticks of Heavy Wall Poly Pipe (A62679)
(3) Pieces of 30'...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
