Have you heard the reports about it being very loud? Plus it $4k cheaper?
With the horsepower range of these tractors, 5 more horses makes much more difference than it would if we were talking the difference between 90 HP and 95 HP. I've read comments from people who indicated that the L2501 "can do everything an L-xxxx (bigger tractor) can do, it just takes a little longer". Regardless of the size tractor, there will always be a time when it would be nice to have a little more weight or a few more horses. My goal is to have that be a rare occasion rather than a common occurrence.
The L2501 has the L3400 34HP engine from two generations ago, and it’s a larger engine than what came in the L3200 from one generation ago. In terms of weight and engine grunt down low, the L2501 is better than the L3200. The limitation to 25HP is based on RPM, so for 2200RPM and below the L2501 will be a very capable machine. Where it will fall short is PTO operation, where you will indeed miss the extra HP. But when I look at what I do with my L3200, the 2501 will be as good or better for about 90-95% of what I do. If I was shopping for a new L right now, the 2501 would be at the top of the list. If someone can figure out how to defeat the RPM limiter it would be a pretty awesome 34HP machine at a great price. As it stands, it’s a pretty awesome 34HP-equivalent tractor at/below 2200RPM.
So what you're saying is the L2501 is a 25HP tractor unless someone figures out a way to monkey with it and most likely void the warranty?
The PTO HP was exactly why I ended up with the L3901 over the 2501. It's a good thing I did because I use the pto for chipping and it isn't hard to stall the 39. I can imagine I would have been frustrated with the 25.
Personally I'd buy a new L2501. It's a little lower on HP, but it's the same engine, just detuned a little to get under 25 HP for emissions reasons.
Personally, I don't know why anyone would buy a 1-5 year old tractor for almost new prices versus buying new. I'd have to see a discount of at least 20% to consider a used machine. That said, $15,900 doesn't sound crazy for that tractor. If you could get him down to 15, and you have the cash, it might be a good way to go. But, the financing from Kubota is tempting.
