Buying first tractor - Need JD Advice on Quote
   / Buying first tractor - Need JD Advice on Quote #11
If you keep your pasture grass well maintained, you want a rear finish mower. Unless your letting it grow and knocking down 5' tall brush and foliage, you don't need a rotary cutter. I've even used a finish mower as a rotary cutter - albeit not the best idea, but it worked.
The quote sounds about right, I'd expect even a little more off.
I would question this Kubota dealer, though. The L2800 is no longer made, and although a nice tractor, is outdated. You'd be better off getting a B series Kubota, which is more comparable anyway. Here is all the information on the 2800, be sure to check out when the end of production is (2004-2010):
TractorData.com Kubota L2800 tractor attachments information
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
1985 Corn Husker Hopper Trailer (A50514)
1985 Corn Husker...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
